Activity Forums Adobe After Effects Project size for 1366×768
  • Project size for 1366×768
    Posted by Lou Wirth on August 17, 2010 at 12:12 am
    I know there has been some discussion on this but not sure I can find the answer. I have to do video for a museum screen that is an NEC 1366×768. The content consists of Hi res stills and titles created entirely in AE so I am not slave to any video. The playback will be from an AMA video player that plays back from its hard drive. https://www.akman.com/index.php?p=AMA1080p
    So given this info, what would be the ideal resolution to create my projects? Should I go 1366×768? what PAR?
    thanks
    Lou
    Walter Soyka replied 16 years, 1 month ago 2 Members · 1 Reply
  • Walter Soyka
    August 17, 2010 at 1:23 am
    [Lou Wirth] “The content consists of Hi res stills and titles created entirely in AE so I am not slave to any video. The playback will be from an AMA video player that plays back from its hard drive. https://www.akman.com/index.php?p=AMA1080p So given this info, what would be the ideal resolution to create my projects? Should I go 1366×768? what PAR?”
    According to the page you linked to, the device plays standard DVD files, 720p, or 1080p. It looks like some scaling will be unavoidable: you can either let the device upscale slightly from 720p, or downscale more substantially from 1080p. In either case, you can use square pixels.
    Maybe 1366×768 is possible, but it’s not a standard video frame size, and you should plan on testing it with the player.
    Walter Soyka
