Activity Forums VEGAS Pro Project Settings Vegas Pro 9
  • Project Settings Vegas Pro 9
    Posted by Escojido Machado on November 14, 2010 at 7:56 am
    Hi, I have been editing for a while using Vegas 6. I just recently got a Sony FX1000 and purchased Vegas 9. I have a few questions.
    1. If I shoot in non-progressive, I assume that I am shooting in 60i. Project settings should be
    Template:hdv 1080i 60i
    Field Order: ?
    Deinterlaced method?
    2. If I shoot progressive 24 p
    Template:hdv 1080i 24p
    Field Order: ?
    3. If I shoot progressive 30 p
    Template:hdv 1080i 30p
    Field Order: ?
    When rendering,to mpeg 2
    field order?
    Any help would be appreciated. Also, if someone could point me to some literature or threads to help me understand deinterlace and field order.
    Escojido Machado replied 15 years, 10 months ago 2 Members · 2 Replies
  • John Rofrano
    November 14, 2010 at 8:04 pm
    [Escojido Machado] ” Also, if someone could point me to some literature or threads to help me understand deinterlace and field order.”
    There is really nothing that you need to understand because Vegas Pro has templates for all of these formats and you should simply use the templates and don’t change anything. Especially don’t change the Deinterlace method from the default setting of Blend Fields unless you have very fast motion that shows a lot of interlace tearing in which case you can change it to Interpolate Fields. Never, every, never set it to None unless you are using your own deinterlace plug-in and want to override Vegas’s default behavior (read: only use None if you are absolutely positive that you know what you are doing and are prepared to handle deinterlacing some other way!)
    BTW the deinterlace method DOES NOT by itself deinterlace your footage. It simply instructs Vegas which method to use SHOULD it have to deinterlace the footage for any reason. Some people say that you can set it to None if you are working totally with progressive footage and while this is true… it is totally unnecessary since Vegas will never need to deinterlace the footage and will simply not use the setting.
    Here are the answers to your questions:
    Template: HDV 1080-60i (1440×1080, 29.970 fps)
    Field Order: Upper field first
    Deinterlaced method: Blend fields
    Template: HDV 1080-24p (1440×1080, 23.976 fps)
    Field Order: None (progressive)
    For what purpose? Just use the render templates that are available and don’t change anything about them. If you are making a DVD use the MPEG2 template DVD Architect NTSC Widescreen video stream and render your audio as Dolby Digital AC3.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Escojido Machado
    November 15, 2010 at 3:52 am
    John, thanks a million for your help.
