Activity Forums VEGAS Pro Project Settings for Sony HDR-PJ10
  • Project Settings for Sony HDR-PJ10
    Posted by Rob James on July 18, 2011 at 11:34 pm
    What would be the best Project Settings for importing and editing HD footage from my Sony HDR-PJ10? Would it be HDV 1080-60i (1440 X 1080, 29.970 fps) or HD 1080-60i (1920 X 1080, 29.970 fps) What is the difference between the two? Full-resolution rendering quality: is set to Best, right? What about the pixel format: Mine is 8-bit that can’t be right, can it? A secondary question. To output the highest resolution possible to Blu-Ray Disc, what steps are involved? Do I have to Prepare and Burn in DVD Architect the way it was with DVD’s or is their a new direct method now? I read somewhere about exporting to .m2t and burning as a Data Disc onto a DVD, and Blu-Ray would be able to read it. Or is that just pure misinformation?
    Rob,
    https://www.robjames.net
    John Rofrano replied 15 years, 1 month ago 2 Members · 3 Replies
  • John Rofrano
    July 19, 2011 at 1:46 am
    [Rob James] “What would be the best Project Settings for importing and editing HD footage from my Sony HDR-PJ10? Would it be HDV 1080-60i (1440 X 1080, 29.970 fps) or HD 1080-60i (1920 X 1080, 29.970 fps)”
    For that camera you should use HD 1080-60i (1920 X 1080, 29.970 fps).
    [Rob James] “What is the difference between the two?”
    HDV is for use with HDV cameras which use non-square pixels and have less horizontal resolution. Your camera shoots 1920×1080 so that’s what you should use.
    [Rob James] “Full-resolution rendering quality: is set to Best, right?”
    Nope. Best is only needed if you are resizing large images. Good is the preferred method for straight video editing.
    [Rob James] “What about the pixel format: Mine is 8-bit that can’t be right, can it?”
    Yes, that is exactly right. 8-bit is the default and unless you have a real good reason to change the defaults, you should use them.
    [Rob James] “A secondary question. To output the highest resolution possible to Blu-Ray Disc, what steps are involved? Do I have to Prepare and Burn in DVD Architect the way it was with DVD’s or is their a new direct method now?”
    Yes. You render to one of the Blu-ray formats (MPEG2 or AVCHD) using one of the supplied Blu-ray templates and author in DVD Architect just like you do with DVD’s. Nothing is different except the formats. You can burn a Blu-ray directly from the timeline but it won’t have any menus.
    [Rob James] ” I read somewhere about exporting to .m2t and burning as a Data Disc onto a DVD, and Blu-Ray would be able to read it. Or is that just pure misinformation?”
    Misinformation. I believe that works with a Playstation 3 but not a normal Blu-ray player.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rob James
    July 19, 2011 at 2:53 am
    Thanks John, absolute stellar information………exactly what I needed!! Thanks so much. I will act on that information. The future looks bright, thanks again my friend!!
    Rob,
  • John Rofrano
    July 19, 2011 at 12:20 pm
    You’re welcome. Glad I could help.
    ~jr
