Activity › Forums › Avid Media Composer › project settings for 1080i 25fps footage
  • project settings for 1080i 25fps footage
    Posted by Jonathan Ehrlich on February 17, 2016 at 10:23 am
    Hi
    I have footage that was shot at 1080i and 25 fps.
    When opening a new project in Avid though, I only have the option to choose between 1080i/50 or 1080p/25, which means that either the frame rate or the scan type don’t fit the footage.
    After asking a couple of people I decided to open it as a 1080i/50 project and imported all the media. But I still have my doubts about it. Did I make the right choice? I already started editing, so should I maybe batch import the footage with different format settings? Are there maybe additional settings hidden somewhere that I can control in order to make the project type compatible with my footage? What DNXHD setting should I use (does this matter)?
    Yesterday I exported a little sequence and needless to say I had the interlace-stripes in the exported clip. I don’t know if this would naturally happen because the footage was shot interlaced or could I have avoided the stripes by choosing different settings?
    A lot of questions, but I am a little confused about this entire thing, so I hope someone here can give me a little guidance.
    Jonathan Ehrlich replied 10 years, 7 months ago 3 Members · 3 Replies
  • Ricky Barrow
    February 17, 2016 at 2:21 pm
    you di correctly – 1080p 25fps is Avid 1080i/50 – progressive frames interlaced is doubled, so 25fps progressive = 1080″p” = 1080p/25. 25fps interlaced = 1080″i” = 1080i/50
    Ricky
  • Shane Ross
    February 17, 2016 at 6:40 pm
    The number after the “i” or “p” indicates how many IMAGES per second there are. So…
    1080p25 means 1920×1080…progressive…25fps.
    1080i50 means 1920×1080…interlaced…25fps (since interlacing is two fields per frame, thus that number after the “i” is doubled).
    Shane
    Little Frog Post
  • Jonathan Ehrlich
    February 18, 2016 at 4:44 pm
    OK. thanks Ricky and Shane, that is good to know. What does that mean for my further workflow. Let’s say I want to export a sequence from the project and upload it to YouTube. Will I have to deinterlace every time or is there a way to change the export settings so Avid exports the sequence as a progressive file?
