Activity Forums VEGAS Pro Project Settings Best/Good creates duplicate frames?
  • Project Settings Best/Good creates duplicate frames?
    Posted by John Frank on August 5, 2009 at 12:10 am
    Hey, I’ve been noticing this since version 6.0 every time I create a lossless (or any type I think) file with project settings as Good or Best under the custom render tab it creates abunch of frames fading into each other… But when I use Preview / Draft it doesn’t do this, it keeps everything like it originally was.
    Have any of you noticed this and have any idea why it does this? I’m not sure if I should be using Best or Preview because of this (I see no quality difference in the two btw, except for the tweening of frames “Best” setting does.
    John Frank replied 17 years, 1 month ago 2 Members · 3 Replies
  • D. Eric franks
    August 5, 2009 at 3:42 pm
    I’m not certain what the render end of things does, but I do know that in the Preview window, there’s often a big difference between Preview mode and Best (Full) mode, especially where it concerns deinterlacing and (as I suspect in your case) conforming different frame rates to the output. So, just for example, if you are using 60i source in a 24p project, any issues you might have might not reveal themselves until you pop the Preview window up to Best (Full). Another way to see where you might have problems is to zoom in to the frame level, where you’ll see that the frame markers on your clip do not match up with the frames on your timeline. Not necessarily a problem (indeed it’s usually not a problem, since Vegas handles this conversion automatically), but the app does need to make a decision about where the last frame in a 60i clip is on a 24p timeline and it may be a frame before or after where you want it! You can also see this when you drag your clips around: sometimes they won’t want to butt up against each other and will either leave a gap or a one-frame crossfade.
    I always render out Best and check out my projects at Best (Full) in the Preview window in the final stages, just before encoding.
    ______________
    Film will only became an art when its materials are as inexpensive as pencil and paper.
    — Jean Cocteau —
    https://videopia.org
  • John Frank
    August 5, 2009 at 9:03 pm
    Hmm, I really want to get to the bottom of this, my project framerate and video framerate were the same.
    Here’s what’s going on [I took screen shots of Best/Preview in the preview window]
    Best / Good [Full]
    https://img81.imageshack.us/img81/9003/bestfullgoodfull.jpg
    Preview Full
    https://img22.imageshack.us/img22/6199/previewfull.jpg
    note: It doesnt matter if its full/half or anything it does the same thing, and when I render with Best/Good it causes that frame tween effect you see on the first shot, but only on fast motion shots usally
    Here’s the properties box of project settings and the clip
    https://img199.imageshack.us/img199/3412/propertiesi.jpg
    I recorded the clip with Fraps at 29.970FPS progressive, right now its zooming out kind of fast. [it seems to only happen on fast motion, maybe it’s trying to add a motion blur?]
    I’ve had this problem on DVD ripped footage also, so it’s not confined to this game clip.
    This is what is in the Vegas manual under render settings:
    Choose a setting from the drop-down list to set the quality of the rendered video.
    Unless you have specific performance problems, choose Good. Choosing Best can dramatically increase rendering times.
    Good uses bilinear scaling without integration, while Best uses bicubic scaling with integration. If you’re using high-resolution stills (or video) that will be scaled down to the final output size, choosing Best can prevent artifacts.
    I’m not sure if it’s suppose to do that to your footage, but I’ve taken already filmed footage before from a movie to play around with in Vegas and when rendering on best it altered big time from the original source, all of the fast parts had that frame tween effect you seen.
    This has been keeping me from rendering everything at Best/Good for a long time, I’ve always used Preview and I really don’t notice any degrade in the video between Preview and the Original. I wish they could list what Preview does in the Vegas manual as opposed to Best/Good
  • John Frank
    August 7, 2009 at 9:28 pm
    Anyone got any idea? Still confused about this :S
