Activity › Forums › Apple Motion › Project settings and fileds
  • Project settings and fileds
    Posted by Victor Goretsky on May 18, 2006 at 3:51 pm
    I am looking for the best project settings to work in Motion – FCP or AVID environment. Specifically the field (upper/lower) settings for the canvas-project and then the final export rendering settings. In the project as you create animations it seems it is better to use “no fields” option so you can see objects in non-jagged appearance.
    When I rendered the final version for DV-FCP I’ve used lower field first and no fields settings. So far I didn’t notice any difference. But it mine so far limited experience with Motion. If anybody got any recommendations on field no field settings and correct aspect ratios for DV/AVID workflow I would appreciate.
    Victor
    Noah Kadner replied 20 years, 4 months ago 2 Members · 1 Reply
  • Noah Kadner
    May 18, 2006 at 5:51 pm
    Stick with the DV or lossless presets and you’ll be fine.
    Noah
