Activity › Forums › Apple Final Cut Pro Legacy › Project settings
  • Project settings
    Posted by Roz Power on November 2, 2011 at 8:00 pm
    I am creating a project with high rez stills that will be for the internet.
    They were delivered as – Frame size 3672X2448, Compressor photo jpeg, Square pixels
    I want the option to be able to zoom in on the stills without having to render every time I make a change. I cannot seem to find a combo for this.
    Can anyone advise on the sequence settings I should set under the General tab?
    Roz
    Chris Tompkins replied 14 years, 11 months ago 2 Members · 1 Reply
  • Chris Tompkins
    November 2, 2011 at 10:26 pm
    What are your sequence size and specs now?
    What is your final web delivery size?
    720X480?
    Try a new sequence with:
    1280X720
    DVCPROHD
    24p
    progressive(none)
    Also, your stills may be n the large size, you could drop in PhotoShop and downsize them a bit to like 2500 on the long size. This would still allow for moves.
    Make sure your stills are 72 DPI and RGB.
    When the edit is locked/down/final I would change the sequence compressor to Prores HQ OR 10 bit uncompressed, re render all final.
    Export using “Current Settings”
    drop that file into your compression program for delivery.
    Chris Tompkins
    Video Atlanta LLC
