Activity Forums VEGAS Pro “Project Properties” vs “Render As” in Vegas Pro 10
  • “Project Properties” vs “Render As” in Vegas Pro 10
    Posted by Brad White on September 25, 2012 at 1:38 am
    The New Project default setting in Project Properties is “NTSC DVD (720×480)” which is fine for my DVD projects. I just finished a DVD but now I want to upload a high-def version of it to my Vimeo site. Vimeo allows up to 1920×1080 resolution, which is what I used to shoot the video; one camera set at 60i, the other set at 60p (don’t ask why).
    The question is, can I re-render the saved project (.veg) with a higher resolution template such as “HDV 1080-60i (HDV MPEG-2 .m2t) even though the project was saved at a lower resolution for DVD?
    Second, should I use the Sony AVC/MVC or Main Concept MPEG-2?
    Brad
    Brad White replied 13 years, 11 months ago 3 Members · 3 Replies
  • Mike Kujbida
    September 25, 2012 at 10:14 am
    Yes you can.
    I’m doing this with a series of promo spots right now.
    One version (original footage is 1440 x 1080 60i) gets rendered in SD format (720 x 480).
    I change the project properties to 1920 x 1080, save the veg file under a different name, and render it as 1920 x 1080.
    I render it in MXF format as that’s what the client needs but Sony AVC/MVC should be fine for your needs.
  • Roger Bansemer
    September 25, 2012 at 11:17 am
    All you have to do is change the “properties” for your project and render it again. Your original footage never changes so you didn’t destroy anything.
    Roger Bansemer
  • Brad White
    September 26, 2012 at 7:46 pm
    Thanks for your comments Mike and Roger.
    I’ve tried your suggetions with success. A high definition upload of a large video file to a file sharing site such as Vimeo, takes a long time, even with a broadband connection. 1920×1080 files are too large, but 1280×720 seems a satisfactory compromise for speed and quality.
    Thanks again,
    Brad
