Activity Forums VEGAS Pro Project Properties Field order questions
  • Project Properties Field order questions
    Posted by Kenneth Maultsby on February 11, 2020 at 3:00 am
    Hello, all I am still learning Vegas and have questions on project settings.
    I shoot HD 1920x1080P in 29.970 and 23.976 and 60 fps
    I shoot UHD 3840×2860 in 23.976 29.970 and 60 fps
    What do I set my Field order?
    Graham Bernard replied 6 years, 7 months ago 3 Members · 2 Replies
  • Wayne Waag
    February 11, 2020 at 6:14 am
    Most likely–progressive. The best way is to use the free app MediaInfo. Here is an example of footage from a Panasonic FZ2500 showing the footage to be progressive.
    You could also just drag the clip to the timeline and let Vegas set properties. You will see a dialog like this.
    Of the two, use of MediaInfo is probably the most accurate.
    wwaag
  • Graham Bernard
    February 11, 2020 at 7:24 am
    [Kenneth Maultsby] “What do I set my Field order?”
    Hi Kenneth! What Wayne said informs you about the characteristics of the Media you shot. Here your HD, is Progressive. It is shot one whole frame after another – Progressively. You asking the question about Field Order suggests to me you aren’t aware of the difference between Progressive and Interlace. Is UHD interlace? Your HD is solely Progressive. Interlace relates to the process of capturing/filming in Interlace, one Field after another Field, hence FIELD ORDER. Unless you are doing something requiring you to explore creating Interlace from Progressive – I doubt it ???? – then leave Field Order alone. You don’t need it.
    All this comes down to establishing if your UHD is Interlace….. or not!
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
