Activity Forums Apple Final Cut Pro Legacy Project not saving
  • Project not saving
    Posted by Ken Zukin on May 9, 2007 at 9:25 pm
    I’m having a recurring problem where I will save a project, close down FCP (leaving my G5 2Ghz DP tower “on”), come back the following morning, open the project from the “file/open/recent” drop-down, and find that my project is an earlier version than the one I had closed.
    At that point, I’ve gone to my auto save vault, and re-opened the most recent version, but in the process I’ve lost a couple of hours work, as the auto-save-vault version may or may not be totally up to date.
    Any idea why this is happening?
    I have the most recent versions of FCP, & QT. I have 4 GB Ram, a 1 TB SATA storage set up with drives that are not filled up, am capturing with an Aurora Pipe Pro cap. card that’s been rock solid. I’m working in a SD environment – using a Panasonic SD93 DVCPRO50 deck.
    Thanks, in advance.
    Ken Zukin replied 19 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
