Activity › Forums › Boris FX Particle Illusion › Project not saving
Project not saving
Posted by Shannon Mccalley on March 6, 2009 at 12:10 amI am running the demo for ParticleIllusionSE, and it won’t save any of my project files. It says the demo is fully functional–is this true?
Shannon Mccalley replied 17 years, 6 months ago 3 Members · 6 Replies -
Steve Stryker
March 7, 2009 at 2:36 amIt’s been a while, but I think when I tried it, it did save.
What is it doing or not doing? Not to insult, but maybe it is saving to somplace you are not looking?Sony Vegas, Particle Illusion, NOOB!
Shannon Mccalley
March 7, 2009 at 2:50 pmThe save button is grayed out, so there is never a file made at all. I’m not sure it’s a permissions issue, because I can save the libraries (indeed, I’ve been making do with doing my editing there!), but I get the idea it’s supposed to be able to save actual projects…
Alan Lorence
March 9, 2009 at 2:20 pmYes, the demo should be able to save project files. (Note that this is not the same as “saving output” or rendering. To do that, click the red “save output” button.)
When you click the “save” button and the dialog opens, make sure that you’ve chosen a folder where you have write access (like “Documents” or “Desktop”), and type a short, simple filename for the project. See if that helps.
Also, make sure you’re not using an old version of the demo. If you recently (in the last month) downloaded it directly from our site, you should have the latest.
Alan.
Shannon Mccalley
March 9, 2009 at 3:00 pmAs far as I know, I have write permission–every other program saves fine, I can copy/paste things without trouble. ParticleIllusion itself makes video files of the particles just fine, and it can save the library file, but not the project file. I downloaded the demo last week.
Ah well. Thanks, though..
-Shannon -
Alan Lorence
March 9, 2009 at 4:11 pmHave you tried selecting all of the text in the filename edit box and typing something new? I wonder if there are some weird characters in there that are causing problems.
Alan.
Shannon Mccalley
March 9, 2009 at 4:47 pmYeah, it normally comes up as ‘untitled’ and erasing the box and putting in new stuff doesn’t change it.
