Activity Forums Apple Final Cut Pro Project names – how to change font size?
  • Project names – how to change font size?
    Posted by Alex Lisowski on October 11, 2011 at 9:23 pm
    I often want to use long project names (as I would have done for sequences in FCP7) but the default project library window does not allow the names to be shown in full. Anyone know if there’s a way to do this either by decreasing the font size or by increasing the space allocated to project names?
    If this has already been dealt with in the forums please point me at it and apologies as my searches came up with nothing.
    Alex
    FCP X 10.0.1
    Mac 0S X 10.6.8
    Macbook Pro 2.3GHz i7 8Gb Ram
    James Ewart replied 12 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Mark Morache
    October 11, 2011 at 11:17 pm
    I’m thinking it might be time to keep your project names to no more than 25-30 characters.
    Any reason why you need more than that?
    Personally, I like short and simple. When I import my footage from the camera, and it wants to name a clip something like 20111011162355_A002_C003.mov, I rename all the clips to something short with a serial number attached like Grad11_001.mov.
    It’s much easier to manage clips and sequences in the bin I think, with shorter names.
    FCX. She tempts me, abuses me, beats me up, makes me feel worthless, then in the end she comes around, helps me get my work done, gives me hope and I can’t stop thinking about her.
    Mark Morache
    Avid/Xpri/FCP7/FCX
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
  • Alex Lisowski
    October 12, 2011 at 2:31 am
    Thanks for the quick response. Good point that I should try to keep the names short. I try as much as I can but I find that I want to make sure I have a record of what program title is, what sequence it is and at a high level what changes have been made. To keep this all readable/understandable for me (and anyone else) now and in the future, I prefer to minimize the amount of abbreviations. However it sounds like that may not be possible, if I want to view the whole title in the project window.
    Thanks again.
  • Kevin Patrick
    October 12, 2011 at 2:39 am
    It does seem odd. I have FCP X open on an LED Cinema display and yet it seems like only 10% of the space is allocated to the Project name and the rest of the 90% to a film strip of the project.
    I suggest sending Apple feedback.
  • Mark Morache
    October 12, 2011 at 10:44 am
    I have a trick for that. I create a title at the top of the clip, like a slate. You can place into that as much info as you want about program titles, version number, and every little change you made. I generally make this one or two frames and make it the first frame of the sequence. This gives anyone who needs to watch and approve of it the same information.
    Make a new version of your sequence, and change the text in the first frame.
    Don’t want to export it in the clip, and you can just turn it off, keeping it at the top of the sequence.
    This still gives you 25 or so characters to label your timeline. You won’t need to abbreviate too much.
    This works for me.
    Mark Morache
    Avid/Xpri/FCP7/FCX
  • Nick Toth
    October 12, 2011 at 2:36 pm
    I agree. I sent feedback on this. I want to be able to see the entire project name in the project library.
    NT
  • Alex Lisowski
    October 13, 2011 at 12:09 am
    Thanks everyone for all the comments and suggestions. I’ll send feedback to Apple about this.
  • James Ewart
    November 13, 2013 at 7:42 pm
    me too…
