Activity Forums Avid Media Composer Project Migration PC > Mac > PC
  • Project Migration PC > Mac > PC
    Posted by Chip Hess on January 17, 2013 at 4:32 pm
    I have MC on a PC at work and Mac at home, same version.
    Starting to experiment with shuttling projects back and forth.
    Now the formatting the portable hard drive issue comes up.
    Is there a format readable by both Mac and PC?
    Even if I partition a drive, will both systems
    be able to see the material on each other’s partition?
    Thanks in advance for any suggestions!
    Jeff Greenberg replied 13 years, 8 months ago 3 Members · 2 Replies
  • Job Ter burg
    January 18, 2013 at 7:26 am
    There’s things like Paragon NTFS for Mac and MediaFour MacDrive (PC) that allow you to use either NTFS or HFS+. I have these installed on my Macs and PC’s, so that I won’t necessarily have to care about the drive format.
    My gut tells me that using HFS+ drive on a PC (with MacDrive) is somewhat faster than using NFTS on Macs, but I’ve never done any benchmark testing.
    Officially, Avid won’t bless using NTFS media drives on Mac nor HFS+ media drives on PC, and it does slow the drive speed slightly, but for generic editing, I have found it to just work.
  • Jeff Greenberg
    January 18, 2013 at 12:09 pm
    If you’re on Vista or later, your best bet is exFat – Disk utilities can format the drive like this for you.
    Unlike Fat32, exFAT allows greater than 2 GB sized files. It’s readable by both current Macs and the PC.
    I’m a big fan also of installing on the PC MacDrive and then you can access HFS+ volumes.
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
