Activity › Forums › Boris FX › Project metadata
  • Project metadata
    Posted by Steve Pankow on April 1, 2010 at 5:25 pm
    Does BorisFX ever see a day when .red files would contain the comp dimension data? It would be nice to open a project and have Red auto-size itself to the saved dimensions rather than having to do it manually. It would also be nice to be able to double click a .red file and have it open rather than starting the software first.
    Steve Pankow replied 16 years, 5 months ago 3 Members · 5 Replies
  • Jon Kozenko
    April 1, 2010 at 8:08 pm
    Steve,
    The Comp size information does follow a .red file, as it’s part of the project settings. Are you using RED as a stand-alone program, or as a plug-in for another Host? I ask because if you are using RED as a plug-in for another host, the project setting information (such as size and frame-rate) would be dictated by the Host’s specifications.
  • Steve Pankow
    April 1, 2010 at 8:23 pm
    Stand-alone. I should add this is version 3.0.4.050929. Is there something in Preferences that should be on?
    I can start Red with a new project, see that Preferences is set to say 720×486 and then open a project that I know was set at 330×75 yet the comp size doesn’t change as seen in Preferences.
  • Steve Pankow
    April 7, 2010 at 7:29 pm
    Bump. Am I misinterpreting what’s going on with the project size settings?
  • Matt Mullen
    April 8, 2010 at 3:22 pm
    Steve,
    I think part of your problem here is you are using Red 3.
    You might want to do a test drive of Red 4,
  • Steve Pankow
    April 8, 2010 at 3:31 pm
    Yep, 4 works.
