Activity Forums Adobe Premiere Pro Project Manager in CS6 won’t trim clips
  • Project Manager in CS6 won’t trim clips
    Posted by Jesse Koepke on March 19, 2013 at 9:06 pm
    Hey all,
    I recently finished editing an hour-long live concert and I need to archive it. However, Premiere CS6 (version 6.0.2, running on Mac 10.6.8) won’t trim all of the clips.
    I have three angles, all of which are DVCPRO HD 1080i60, 29.97fps. One angle is the primary, and on rare occasion I cut to the other two angles. The raw footage of those three angles add up to 250GB. However, when I select Project Manager for just final the sequence and choose Create New Trimmed Project, the archived file size comes out to 350GB. It trims only about half of the secondary angles, leaving the rest as full-length clips.
    I used to run into this problem in Final Cut Pro 7 and it usually had to do with long clips not having a reel number assigned, but changing that didn’t help in Premiere. Also an interesting note, when I select Project Manager for the “trimmed” project, it now estimates a file size of 70GB. So there’s something in the original files that isn’t reading correctly in Premiere.
    Any ideas?
    Joe Ashe replied 11 years, 4 months ago 7 Members · 12 Replies
  • 12 Replies
  • Angelo Lorenzo
    March 19, 2013 at 9:10 pm
    Did you go to Edit > Remove unused before using the project manager? For other really technical reasons, I’ve found that this command does a lot of behind-the-scenes housekeeping to the structure of the Premiere project file.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Jesse Koepke
    March 19, 2013 at 9:38 pm
    I didn’t use any other assets besides the three angles, so the Remove Unused Footage was grayed out. For good measure, I threw a few random clips in and then selected Remove, but it didn’t change anything.
  • Jesse Koepke
    March 20, 2013 at 5:56 pm
    Anyone have ideas for this?
  • Alex Udell
    March 21, 2013 at 8:27 am
    Hiya…
    Did you cut manually or use Multicam?
    If you used multicam, then your multicam edit is dependent on the full length of the source clips in the Multicam source sequence.
    Thus….there is no media to trim. All original source is required to archive the project.
    The thing about multicam in PPro, is that its a visual cut referring to the nested sequence, and not a direct reference to the clips in the Project panel.
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Jesse Koepke
    March 21, 2013 at 4:51 pm
    The concert was cut manually. That’s an interesting note about the multicam, though. It’s a shame there isn’t a way to collapse the multicam and just archive the active angles.
  • Alex Udell
    March 21, 2013 at 7:58 pm
    Ok….If it’s still not trimming and you cut it manually….
    this may indicate that it doesn’t think that it’s a codec structure that it can consolidate for some reason.
    I don’t know why it would think that about DVCProHD.
    that’s not GOP structured media….
    hmmm….
    Alex Udell
  • Alex Udell
    March 22, 2013 at 1:42 pm
    Out of curiosity…
    You don’t by chance have more than 1 instance of an angle imported into your project panel that you may have cut with?
    If this is true…then PPro will likely think of those as 2 separate media files when doing the archive…thus possibly duplicating media unnecessarily…
    just trying to think of anything that might contribute to this….
    Alex Udell
  • Jesse Koepke
    March 25, 2013 at 5:14 pm
    No, I just had the three angles and the individual song mixes in the project.
    An interesting note is that I had Premiere media manage the project (all 350GB), and then I opened the media managed project and managed that project—and then it trimmed files correctly. So I guess there must have been something in the original footage that didn’t read right? Final Cut Pro 7 used to have a problem like that, where the footage had to have reels assigned.
  • Wesley Dean
    March 25, 2013 at 10:57 pm
    I’m having the exact same problem you are. When I told Premiere to trim the project, it simply copied all of the original files over. However when I opened up that project and told it to trim everything again it actually trimmed the clips. The first time I copied all of the files over it was around 200 GB and the second time it whittled everything down to 20 GB, which is much more manageable and I can back them up to BD. Most of the files are in ProRes LT, btw.
    So the probable isn’t unique to you. Does anyone else have any ideas, or does this need to go to Adobe?
  • Andrew Milner
    May 18, 2013 at 10:26 pm
    I’m having the same issue with H264 video.
