Activity › Forums › Adobe Premiere Pro › Project Manager
  • Project Manager
    Posted by Ryan Melling on November 15, 2012 at 1:38 am
    I’m a recent convert to Premiere Pro. The company I work for was running FCP6 and we desperately needed an upgrade. PP has been really amazing on the ingest/edit/encode process, but we’ve now come to the point with a couple shows where in FCP we would Media Manage only the clips used with handles to an Archive drive.
    It seems Project Manager is set up to run the same way Media Manager would, but I get an error message every time I attempt it. I’ve got 2 different machines I’ve tried this feature on and they both fail. I’ve read a few other forums with people having this problem. Anyone at the Cow have a solution to this? or is it just a buggy feature right now, and we’ll just have to live without it? Has anyone had success with this feature? I’m using Canon xf305 footage and have tried it every different way there is. Ideally I want clips with handles, but if I had to copy the entire original clip I would accept that as well.
    Michel Gallone replied 13 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Tom Daigon
    November 15, 2012 at 5:22 am
    If your media is h.264 then PrP cannot truncate the clips to match what was used in your sequence due to the long GOP form of compression used on the clips.
    If they were Prores or DNxHD the PM would do exactly as you desired since they dont use a long GOP style of compression.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Al Bergstein
    November 15, 2012 at 3:08 pm
    I don’t understand. I was under the impression that the Canon MXF format is not H.264 but MPEG2. It is long GOP though. Does your answer still make sense if it’s MPEG2? I would assume you would say yes, as the answer would be that whether the footage is H.264 or MPEG2 (or 4) it would not work because it’s Long GOP.
    Apparently Adobe has said that we should go request a feature to have this done properly. If what you are saying is that it’s the Long GOP format, it doesn’t seem to be something they could implement in trimming.
    Pity that in order to actually trim the footage we have to go back to re-encoding the footage into ProRes or DNxHD! I guess we could argue that it’s the old pay me now or pay me later. Faster editing up front but longer transcoding in the back end.
    So from a practical standpoint: Do I edit all the long GOP footage, then use encoder to export it to DNxHD and then send it to Project Manager? Or is there a different workflow to approach this?
    Al
  • Tom Daigon
    November 15, 2012 at 3:18 pm
    Since you did not mention what the codec was, I was just presenting an example of a long GOP format that would be problematic.It sounds like that applys to MPEG2 since you keep getting the error message. I have worked with h.264 but not MPEG 2 as a media source.
    I believe your only option at this point, with the completed project is to archive the whole thing. And depending on size that could require a single or double Blu ray disk. Or a hard drive. Or an LTO-5 tape system…
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
  • Ryan Melling
    November 15, 2012 at 11:46 pm
    The problem I have doesn’t even allow for me to use project manager at all. Whether I want to trim or move the entire project. Are you saying that I could transcode my .mxf files in the sequence as something like prores or DNxHD? And then possibly use the project manager? That could be something I’d be OK with as it would still be less time transcoding than when we were using an offline editing system.
  • Tom Daigon
    November 16, 2012 at 12:15 am
    You should be able to copy the project, just not create trimmed clips.
    Wosrt case scenario, just copy all the necessary files yourself to what ever storage device you choose.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
  • Ryan Melling
    November 16, 2012 at 7:54 pm
    I can surely do this manually through the finder, but its a hell of a lot more work. I guess I was just wondering if anyone else is having the same issues? Has anyone solved their issues? Or if they can get it to work, what codec are they using? Could the difficulty just be in the codec?
  • Michel Gallone
    July 4, 2013 at 7:17 pm
    I can confirm that with Premiere Pro CC as of July 4th 2013, the issue with Long Gop mpeg and H.264 when trimming a project in Project Manager has not been fixed yet.
    That really mean that we should follow the good old habit of transcoding to ProRes or DNxHD if we ever think that we might want to save a trimmed version of the final project.
    Hopefully the adobe team will eventually get it solved.
    Michel Gallone
    Sowatt Music sàrl
    Music Post and Shooting
    https://sowattmusic.com
