Activity › Forums › Apple Final Cut Pro › Project “lost” when RAID accidentally disconnected
  • Project “lost” when RAID accidentally disconnected
    Posted by Howard Bernstein on June 13, 2016 at 6:34 pm
    I lost a couple of hours worth of edits this morning. My thunderbird drive was accidentally disconnected. Final Cut Pro X came up with some kind of dialog as now nothing in the project was accessible. Rather than make the mistake of reconnecting something incorrectly, I force quit FCP X, and when I reconnected the RAID, the system rebooted.
    Reopening FCP X, the library has a warning sign, and the project is annotated with “no data”. I can open a backup from before I started editing today, but there is nothing after that.
    If I open the library package, there is a project folder, with what appears to be some data file in it, but I have no idea how to, or if I can, reconnect that file, or even if my edits are held within.
    Any help would be greatly appreciated.
    Howie
    Brett Sherman replied 10 years, 3 months ago 5 Members · 15 Replies
  • 15 Replies
  • Bret Williams
    June 13, 2016 at 10:29 pm
    Backups are made every 15 minutes. How are you accessing the backup?
  • Darren Roark
    June 13, 2016 at 10:31 pm
    What Brett said, and the backups are by default inside your movies folder.
    Try opening the most recent backup and see if that gets you up and running.
  • Howard Bernstein
    June 13, 2016 at 10:40 pm
    I used “File->Library->Open Library->From Backup…” The latest one was from 10:15am, but I finished editing around noon.
  • Darren Roark
    June 13, 2016 at 10:45 pm
    See if there is one in your fcp backups folder in your movies folder that is newer.
    It’s possible that the corrupted library is unaware of a more recent backup.
  • Howard Bernstein
    June 13, 2016 at 10:58 pm
    There isn’t 🙁 But in the library that’s “corrupted” there is a currentversion.fcpevent file that has a more recent time on it. I’m tempted to try copying it into the backup to see if it has the edits? Is that where the edits are stored?
  • Darren Roark
    June 13, 2016 at 11:04 pm
    You can certainly try that. Just make sure you duplicate anything you try to do surgery on.
    You can also try deleting the ‘flexolibrary’ but again, make sure it’s to a copy of the library you are trying to revive.
  • Howard Bernstein
    June 13, 2016 at 11:29 pm
    Copying the currentversion.fcpevent didn’t seem to make a difference. What’s the “flexolibrary”? I didn’t see anything with that name.
  • Darren Roark
    June 13, 2016 at 11:38 pm
    [Howard Bernstein] “What’s the “flexolibrary”? I didn’t see anything with that name.”
    Do a search inside the library.
    It may not do any good. That trick helps when the library won’t open at all.
  • Howard Bernstein
    June 14, 2016 at 2:15 am
    That didn’t work. I’m really disappointed in FCPX. Oh well.
    Thanks for all the suggestions.
    -Howie
  • Darren Roark
    June 14, 2016 at 3:54 am
    [Howard Bernstein] “That didn’t work. I’m really disappointed in FCPX. Oh well.”
    I’m sorry this happened, FCP X isn’t perfect.
    I know this isn’t helpful for this situation but I wonder why FCP X didn’t back up your library all that time?
