Activity Forums Adobe Premiere Pro project import question for 2.0
  • project import question for 2.0
    Posted by Baba Goof on January 17, 2006 at 10:11 pm
    wondering if this has changed/improved in 2.0. when i imported
    a project into another project in 1.5, redundant clips could
    not be removed and re-associated to a single instance of the
    clip without losing the timeline references to the ones being
    removed. this resulted in there being sometimes a great many
    instances of a certain (or several) clips in the project
    creating a lot of clutter.
    if my project uses clip ‘a’ and i import 3 more projects which
    also each use clip ‘a’, i wind up with a total of 4 instances
    of clip ‘a’. if i try to delete the extra instances of clip ‘a’
    i can’t do so without them disappearing from the sequences in
    the imported projects.
    what i want to do is take the imported redundant clips off line
    and then re-associate the clips in the timeline to the original
    from the original project.
    can i do this now in 2.0?
    thanks,
    BabaG
    Baba Goof replied 20 years, 8 months ago 3 Members · 3 Replies
  • Jacob Rosenberg
    January 17, 2006 at 10:23 pm
    Unfortunately, if you were to import two project that referenced the same media, it would pull in two instances of that clip, one for each project. From your comments, it would appear that this is consistent with 1.5.
    jacob
    http://www.premiereprotraining.com
    http://www.formikafilms.com
    http://www.d2gfilm.com
  • Steven L. gotz
    January 18, 2006 at 2:50 am
    However, since conforming is not necessary for DV clips, you won’t get multiple conformed files at least.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Baba Goof
    January 18, 2006 at 6:04 pm
    well, that’s something, i guess. but imagine this
    scenario:
    i have a piece with 30 scenes, each of which makes
    use of a library in addition to its own clips. if
    i want to employ a workflow in which i put each
    scene into its own project and import all of these
    edited projects into a master project later, then
    the master project will have 30 instances of the
    library and all its clips. very inconvenient.
    thanks,
    BabaG
