Activity › Forums › Adobe Premiere Pro › Project from PAL to NTSC, I’ve been a little stupid..
  • Project from PAL to NTSC, I’ve been a little stupid..
    Posted by Princess on May 22, 2006 at 9:52 am
    I’ve got 2 different projects, one is in PAL the other in NTSC.
    The film is recorded in widescreen mode,the project size was 720×480, so I changed the motion in the NTSC project to:
    postition 460x 240
    the scale to 64
    and the anchor point to 461 x 288
    I’m sure this wasn’t the right way to do it, but it was the only right way to show everything without stretching the movie too much.And I like the black bars.It was the only thing I could think of, cause I’m pretty new to premiere.
    Thing is, here in Holland we work with PAL, so I had to render the NTSC movie to a PAL movie.
    Everything worked fine and it looks good on TV.
    Now I had to make another movie from the same tape, so it was widescreen recorded, I thought I wont make the same mistake again, and opend a PAL project right ahead.
    But now I have to mix the two movies together.
    The thing is,the motion options aren’t the same.
    Because one project is 720×480(NTSC) and the other is 720×576(PAL), I just can’t set the PAL motion at postition 460x 240
    the scale to 64
    and the anchor point to 461 x 288, because than the black bars of the movies aren’t the same size!!
    Can I change the PAL project to a NTSC?And I don’t mean rendering it to an NTSC movie.
    Is there anything else I can do?
    Does someone knows how I’ll get the black bars the same size, without stretching/losing image?
    I hope someone can help me out.
    thanks
    grtz.
    Jeanique
    btw, all movies are captured in PALformat……..and I didn’t use the widescreen mode for the project cause it looked terrible on tv.
    Marcus Van bavel replied 20 years, 4 months ago 2 Members · 1 Reply
