Project freezing after adding special effects_Now almost unusable_Primere pro CS5
Problem: My premiere pro project takes 30 minutes to open and 30 minutes to save. The spinning wheel of doom spins, program freezes. I can open file and can basically work in it (slow) but autosave takes 30 min… in other words all is not lost yet, but I am sweating about finding the best way to repair this problem and and not loose work. I have over 100 hours of work in this project and am desperate for good advice.
Help?!: Can you help me know how to fix the problem with my file or tell me how to transfer the actual content of my project to a few new projects or share how you solved a similar problem?
Background: The problem began when I recently added some special effects to project consisting of 15 seconds of keyframes guiding an object through a motion path frame by frame. The project became slow and now freezes. I frequently have to force quit while working on project when freezing. The project file size was around 250 MB before I added the effect and file grew to 1.7 GB after adding the effects (and Crashed). I recovered a previous auto save (My default settings only kept the past 5 autosaves) but it still had a substantial amount of the effect in the file (750MB file). I deleted the effects from the timeline but project still does not run faster.
I have around 15 sequences in the project ranging from 3 to 12 minutes with minimal transitions, slow and fast motion, etc… ( my computer handled everything in the project extremely fast before adding the effect). It is a rough cut of a full length documentary and a lot of work still needs to be done to the sequences. This is my first full length project and after experiencing this problem I would make the project out of many smaller individual projects in order to not risk loosing everything by messing up one file.
Help? Please!
Premiere Pro CS5 Mac
Raid Array
Raid 4 TB (1.5 Available)
Clone 2 TB (1.42 Available)
Awesome Video Card
Awesome Processors
My hardware is not the issue, it can run other hefty projects with ease
