Activity Forums Apple Final Cut Pro Legacy project flickering?
  • project flickering?
    Posted by Elliot Pollaro on July 17, 2007 at 8:31 pm
    I exported my project about a month ago and I had no flcikering in it, looks as if the video is dragging across the screen. Now im bouncing it again and i have it rendered i just cant figure out why its staggering. It looks fine on the computer and looks very bad on screen only in some areas though.
    Help?
    Sequence settings are:
    720 x 480 NTSC DV (3:2)
    NTSC-CCIR 601 / DV
    Field Dominance: Lower Even
    Compressor DV/DVCPRO-NTSC
    Elliot Pollaro replied 19 years, 2 months ago 2 Members · 2 Replies
  • Shane Ross
    July 17, 2007 at 8:35 pm
    Are you looking at this footage on an external monitor? TV? Because you can never EVER judge the true quality of your image using the computer monitors. They don’t show you a full res full quality image. You can get close if you set your VIEWER or CANVAS to 100%. But really, you need an external monitor.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Elliot Pollaro
    July 17, 2007 at 9:37 pm
    TV
