Activity Forums DaVinci Resolve Project Files
  • Project Files
    Posted by Stephen Smith on November 17, 2014 at 6:53 pm
    I’m finally getting around to backing up projects from years ago. I like to keep all of the editing projects files (PPro & AE), RAW files and everything else I would need to jump back into the project years later if I need to. I realized that I don’t know where DaVinci saves its projects to and if I can even access them? The only thing I can seem to find is “Export Project”.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
    Nat Jencks replied 11 years, 9 months ago 5 Members · 5 Replies
  • Joseph Owens
    November 17, 2014 at 8:07 pm
    [Stephen Smith] “The only thing I can seem to find is “Export Project”.
    In that case, you have discovered how to archive DaVinci projects.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Stephen Smith
    November 17, 2014 at 8:10 pm
    That’s a pain. Oh well. Thanks for the help, I wanted to make sure I was doing this right.
    Stephen Smith
  • Marc Wielage
    November 18, 2014 at 7:07 am
    Yep, and when you export the project(s), make sure it includes the stills. If you want to dot the i’s and cross the t’s, you can also include thumbnails, which will make a bigger project. I also take a snapshot of the directory structure in case I have to redo the session elsewhere on a different computer, which will help preserve the media links in the database.
  • John Knapich
    November 20, 2014 at 5:33 pm
    What about backing up the database? I assume that has all the project info for all of the projects in the db.
    John Knapich
    Creative Director/Partner
    Assembypix.com
  • Nat Jencks
    December 3, 2014 at 3:57 pm
    I would clean up the project removing and unused media and timelines, then export the project as a DRP manually and include LUTs, stills, etc. and use “Resolve Collect” to media manage the media. Reopen the project, connect to the newly media managed media, save and archive to spinning disks or LTO.
    Painful, but I have found exporting to DRP much more reliable than manually copying folders from the database.
    Best-
    -Nat
