Activity › Forums › Apple Final Cut Pro Legacy › project file won’t open
  • project file won’t open
    Posted by Dan Obrien on March 9, 2009 at 12:14 am
    Hello all,
    I have a project that I worked on as recently as Friday, and now it won’t open. I immediately get the helpful “General Error” message whenever I try to open it. It won’t even attempt to load the project or media. I’ve trashed the FCP prefs and it didn’t work.
    I’ve tried to open the autosave files, and get the same result. Like I said, I was just working on this project 2 days ago and everything seemed fine.
    Any suggestions? Thanks in advance.
    FCP ver 5.0
    Power Mac G5 dual 2ghz processor
    2gb ram
    HDV project
    Dan
    Dan Obrien replied 17 years, 6 months ago 3 Members · 4 Replies
  • Michael Sacci
    March 9, 2009 at 3:40 am
    will other FCP project files open?
  • Dan Obrien
    March 9, 2009 at 5:13 am
    Yes, other projects will open. But I found that another HDV project from a few months back won’t open either (same error message). But it’s strange. I’m currently working on a newer HDV project, and it’s opening no problem. I wonder if it’s connected to the HDV material in some way, but I really have no clue what’s going on.
    Dan
  • Victor Perez
    March 9, 2009 at 3:52 pm
    I have had success sometimes by opening the most recent Autosave of a project in some previous versions of FCP 5.
    If you go to:
    System>Users>Documents>Final Cut Pro Documents>Autosave Vault
    you will see a bunch of folders of your Autosaved projects. Find the project you are having trouble with and open the most recent autosave of that project (which should be sometime Friday), and try to open it.
    If it does open I usually do a Save As and rename the project so I don’t try to re-open the troubled project by mistake at a future date.
    good luck,
    Victor
  • Dan Obrien
    March 9, 2009 at 6:12 pm
    Thanks for the response, but unfortunately I already tried opening all of my autosaves from this project (see original post).
    Dan
