Activity Forums Apple Final Cut Pro Legacy Project Export Merged clip properties.
  • Project Export Merged clip properties.
    Posted by Jeremiah Yowly on July 29, 2008 at 5:44 am
    Ok, here is my problem, I’m working on a feature and editing it. We shot on 16mm. And recorded on a Deva, which gave us .bfw which works fine, the tapes were captured at 23.98 but seem to work fine on the time line.
    I created a slew of marks on the original captures so I could use subclips to retain the 24 bit audio for the sound guys. I then exported the audio via AIFF, 24 bit 48hz and imported it back into the project, then I merged the clips, adjusted the timeline, everything is great so far.
    Merged Clips, Subclips all synced, ready to be edited. Then “DRUM ROLL” the problem. I use my media manager to copy the project to an external raid, open the newly copied ones, and the merged clips just go all to #@$@. The merged clip will be there but the Audio will squished up from the video at back and the clip becomes very long???? Does anyone know what’s going on?
    THanks.
    Jeremiah Yowly replied 18 years, 1 month ago 1 Member · 1 Reply
  • Jeremiah Yowly
    July 29, 2008 at 3:49 pm
    I found that during the media manager transfer, the duration of the clips change. I am sure this is the problem. Any thoughts?
    Thanks all,
    Jeremiah
