Activity Forums Adobe Encore DVD Project Exceeds Disc Capacity
  • Project Exceeds Disc Capacity
    Posted by Molly Blank on August 2, 2018 at 3:46 pm
    I am trying to author an ISO (DVD Image selected) through Encore and when I try to build it I get the notice that “Project Exceeds Disc Capacity.” Encore indicates that 882.9 mb are used, 0 bytes are free and 526 kb are used for DVD-Rom content.
    The video is 22 minutes long. The .m2v file is 784.mb and in both Transcode settings and status, it says “don’t transcode.”
    The .wav file is 242 mb. In Transcode status, it says untranscoded and under Transcode settings it indicates “Automatic”
    I would appreciate any help or advice. Why is my disc capacity so small? I exported using MPEG-2 DVD, VBR-1 so pretty standard.
    Stan Jones replied 8 years, 1 month ago 2 Members · 6 Replies
  • Stan Jones
    August 2, 2018 at 4:31 pm
    Please post a screenshot of your build panel. I agree, it makes no sense!
    Stan Jones
  • Molly Blank
    August 3, 2018 at 3:07 pm
    Here it is
  • Molly Blank
    August 3, 2018 at 3:13 pm
    I was just able to export it but when I opened the .ISO file it only had Video_TS – there was no audio and I know it should also open as an image as if I were putting it into a DVD player.
  • Molly Blank
    August 3, 2018 at 3:29 pm
    And lastly, when I just tried to quit Encore I got this message:
  • Stan Jones
    August 4, 2018 at 10:36 am
    The build panel omitted all the disk info. Good you got it to build.
    Encore creates a DVD with only a VIDEO_TS folder. The AUDIO-TS folder is not need for regular DVD audio/video.
    If you opened the .iso and got the folder structure rather than it playing the DVD, you probably “mounted” the iso (like a drive) and saw the files in it. I don’t know if Finder does that automatically or not. A computer DVD player may or may not handle .iso files.
    Stan Jones
  • Stan Jones
    August 4, 2018 at 10:38 am
    An unusual error. I’d restart your Mac and try again.
    Go back to your iso and see if it is not okay. Burn to disk and try in a DVD player.
    Stan Jones
