Activity Forums Adobe Premiere Pro Project done, but wrong settings, possible to change project settings?
  • Project done, but wrong settings, possible to change project settings?
    Posted by Neil Kidney on March 14, 2007 at 8:47 pm
    HI,
    so i’ve built a project in Premiere pro, but its only now that I realise that my project settings are incorrect, it should have been widescreen PAL (1.422), but instead its normal res(1.067).
    The box is greyed out to change it, is it possible to change this without redoing the whole project?
    With a deadline tomorrow morning, its going to be tight 🙁
    Cheers, TBK
    Mike Mattarese replied 17 years, 11 months ago 3 Members · 4 Replies
  • Steven L. gotz
    March 14, 2007 at 9:36 pm
    Create a new project with the correct settings and import the old project into it. Go into the bins and drill down until you can open the original sequences.
    Steven
    https://www.stevengotz.com
  • Neil Kidney
    March 14, 2007 at 9:45 pm
    Fantastic! Cheers Steven.
    theres one thing Im noticing, normal photos are getting stretched, while the video looks fine, when i interpret footage to pixel ratio of 1 (square), it looks ok. so I need to convert all my photos to square PR and the vids can maintain 1.422?
    Thanks again
  • Steven L. gotz
    March 15, 2007 at 12:11 pm
    Yes, well, stills are a different matter, especially if set to scale automatically.
    Steven
  • Mike Mattarese
    September 15, 2008 at 1:59 am
    Hi. I see two fields in the project file XML. If I want to set the resolution to 1400×1050 (“0,0,1400,1050”) what do I set the “PixelAspectRatio”? It’s currently “648,720”. I’m using Adobe Premier Elements.
    Also, do I have to go in and adjust the title’s locations so they are still in the correct place?
