Project dimensions to match photo
I am trying to add images to a project and have the project be 3264 x 2448, which is the pixel dimensions of the images I am using. However, when I drag the image into the project, it does not fit perfectly. There is a black border on the sides and I have to make the scale smaller in order to see the entire image. I have tried “spatial conform” at every setting. But it should work with “none” if I’m doing it right. Does anyone know how to make it so the dimensions of the photo are accurately conveyed to the dimensions of the project? Thank you!
