Activity › Forums › Apple Final Cut Pro › Project crashed – very little saved
  • Project crashed – very little saved
    Posted by Scott Braden on January 22, 2018 at 7:31 pm
    I’m new to FCPX after being away from editing for 7-8 years. Just started work on my first project. While working on this new project I got the spinning color wheel of death that went on and on and on. Finally had to force quit the program. When I reopened – about 2 hours of my work (color correction, titles, etc) was all gone. After crying for a few minutes – I began searching for info on saving (save as, etc) and have come to learn that this version auto saves as you go. I find that interesting – since it just lost 2 hours worth of my work. Any suggestions as to how I retrieve what I had done? Or what safeguards I can add into my workflow to prevent such disasters? Thanks.
    Mark Suszko replied 8 years, 8 months ago 3 Members · 2 Replies
  • Oliver Peters
    January 22, 2018 at 11:34 pm
    FCPX constantly saves and basically does this with every change, so it’s weird that you lost 2 hours of work. You should have a Back-ups folder, though, with auto-saved versions. If you can locate that, you should be able to revert to the last saved version.
    – Oliver
    Oliver Peters – oliverpeters.com
  • Mark Suszko
    January 23, 2018 at 4:22 pm
    Search for autosave vault. And in prefs, you can set how long the machine waits between auto-saves. I’m paranoid so I set that for five minutes. Too much can happen in two hours to risk losing it.
