Activity Forums Adobe Premiere Pro Project appears to be damaged
  • Project appears to be damaged
    Posted by Doug Helsby on January 23, 2021 at 12:04 pm
    I have a number of CS6 projects which i wish to edit. I open cc2019 and the project is converted. I edit project and save twice, one on pc and another on external disk.
    I open project in CC2019 and I get error message ‘project appears to be damaged and cannot be recovered and also the same on external disk.
    A workaround is to open new project, open media browser and manually drag files over and re edit project. Everything is good. Save project and same error message when I reopen project.
    If the CS6 project has been converted, why do I get this message. I have also checked clips have same properties.
    Should I edit CS6 projects back in CS6 or is there something I am doing wrong with CC2019
    Robert Withers replied 5 years, 8 months ago 3 Members · 3 Replies
  • Todd Perchert
    January 23, 2021 at 6:11 pm
    I have no idea if this will help you, but it us something to try – works with some damaged projects.
    Make a new project in CC, then import your CS6 project into that project. See if that helps.
    TC
  • Doug Helsby
    January 23, 2021 at 7:54 pm
    Hi
    Thank you for your thoughts
    I did import to CC from CS6. The project was automatically changed to meet CC. However, despite being able to edit and produce a viewable project , rendered through media encoder and watched as required, and saving the project twice; recovering the project to view later I get the wretched error message. I have double checked the clips properties to ensure they are the same , the problem still remains.
    Auto save folders are empty so cannot go back in history!
    It has been suggested I start a new project, open media browser and import the files again. I tried it with same result.
    I have since decided to edit CS6 projects back in CS6 which I still have . From what I have read on the net, it looks as if CS6 projects are not easily imported and edited in Cc2019.
    Cheers
    Doug
  • Robert Withers
    January 23, 2021 at 11:42 pm
    Hello, Doug.
    I wrestled with this kind of issue with the help of the nice folks on phone support. For hours and days. Working from a vintage laptop running vintage MacOS. I got omething into CC 2019 but need to do some re-editing.
    Good luck,
    R
