Activity Forums AJA Video Systems ProIO Control Panel unexpectedly quits
  • ProIO Control Panel unexpectedly quits
    Posted by Lebrett on February 26, 2006 at 9:00 pm
    This is a brand new installation. I installed 2.1 drivers along with easy setups. But if I double click the control panel it unexpectedly quits. I can’t get it to open and I need to adjust the configuration of the IO board.
    Andy Edwards replied 20 years, 6 months ago 3 Members · 2 Replies
  • Lee Berger
    February 27, 2006 at 11:49 am
    I would contact AJA tech support. They are very responsive.
  • Andy Edwards
    March 1, 2006 at 5:45 am
    Did you update your firmware?
    Did you cycle the power on your IO after it was updated?
    Did you repair permissions of your OS after running the update?
    Do you have FCP open at the same time your trying to adjust the control panel? Try hiding FCP and clicking anywhere on your desktop. Then try and launch the control panel. Or close FCP all together and try it.
    Your download could have been corrupt, as I had this problem on a previous install and had to download again.
    Andy
