Activity › Forums › Adobe After Effects › Progressively bolder letters in a one word layer
  • Michael Szalapski
    March 27, 2018 at 8:07 pm
    The best way is to use a typeface that has several different weighted fonts to it.
    Wait, are you wanting to animate this at all?
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Jacob Roth
    March 27, 2018 at 8:13 pm
    Yes, if possible. The segment is called “Advance at a Glance” and I wanted to have the “dv” in advance wiggle random letters and settle on “Gl.”
    The company’s font does have weighted fonts, but I was hoping to make this happen in one layer so that I can do the animation.
  • Kevin Camp
    March 27, 2018 at 8:34 pm
    you can get close by adding a stroke to your text layer, then adding a text animator for stroke width.
    in the text animator’s settings, goto range selector>advanced and set the ‘shape’ to ‘ramp up. then increase the stroke width property for the animator.
    you”ll also need to decrease the scale a bit, so add a scale animator to the same animator (with the scale width property selected, add a scale animator property and it will then work with the range selector that you have already set).
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Roland R. kahlenberg
    March 27, 2018 at 10:22 pm
    Start off with a font with a “Light” version. Ensure you enable Stroke in the Character Panel. Leave the Stroke value very low – 0.1 is good. Then add a Text Animator Group by selecting Stroke Width from the Text Animator Properties Menu. In the Advanced section, set Shape to Ramp Up and set the Stroke Width to a value of 20 – then adjust the to taste.
    You can try duplicating the Text Animator Group to get the enhanced (non-linear) stroke increments that your example shows, for the characters to the right of the text string.
    PathSlicer – Advanced AE Shape Layer Effect
    https://www.broadcastgems.com/pathSlicer
    – create highly customizable custom animated typefaces
    – create amazing transitions
    – create cool lower 3rds and panels
    – create burst effects
    Do it all on a single Shape layer with minimal keyframes.
    TypeGEMs – The Most Complete Type Tool Effect for AE
    https://www.broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    BorisFX mocha Certified Instructor
