Activity Forums Adobe After Effects Progressive zooming
  • Progressive zooming
    Posted by Valen on April 4, 2005 at 4:56 pm
    I’m spanish and my english is not very good. i’m sorry.
    I never used after effects, but actually i need do something with it.
    I have a map (florida state by example), in adobe illustrator format. I need to do a progressive zoom over a point of the map.
    The result must be a AVI file. How can i do this? What effect must i use? must i use cameras?? i need help
    Regards from SPAIN !!!!
    THANK YOU.
    Valen replied 21 years, 5 months ago 2 Members · 2 Replies
  • Mike Clasby
    April 5, 2005 at 12:30 am
    Import the map.ai file into AE.
    Put the map.ai file into a new Comp (Comp size depends on how you’re going to view it: TV, computer downlaod, the internet?).
    Since it’s an ai vector file you can do what you want just by Scaling the layer. Select the map layer, hit the “S” key.
    Now set a keyframe for Scale by clicking the stop watch. A keyframe should appear in the timeline.
    Also, click on the “Continuously Rasterize icon in the timeline window (looks kind of like a little sun), this will keep the vectors sharp when you scale them up.
    If by progressive zooming you mean oone continuous zoom, go down the timeline to where you want the zoom to end, then change the scale of the layer, making a new keyframe.
    Ctrl M will bring up the render Que, Select an AVI codec and you’re done.
    If this are a real beginner and still lost, try this from the Editor’s Guild, it’s a very good place to start,”Part 2 – Basic Animation” here:
    https://www.editorsguild.com/AfterEffects.html
    Adios, buena suerte. (I hope this means “Good Luck”, highschool spanish was a long time ago).
  • Valen
    April 5, 2005 at 3:19 pm
    Thanks !!! It’s ok
