Activity Forums Apple Motion progressive screengrabs to uncompressed interlaced SD
  • progressive screengrabs to uncompressed interlaced SD
    Posted by Paul Griffiths on April 27, 2009 at 1:49 pm
    Hello!
    Any help with this little problem would be much appreciated
    I’ve captured some screengrabs from the internet with iShowU into Apple Animation 1920×1080 at 24p (as I didn’t want this program to interlace or scale anything).
    I’ve then imported these into an uncompressed PAL SD (FHA) Motion project in order to pan and zoom around it.
    Then I rendered these out as uncompressed PAL SD quicktime files (upper field dominant) and dropped into an uncompressed PAL SD anamorphic (upper field dominant) timeline.
    However! When I play these back on my PAL SD SDI broadcast monitor (an old grade 1 CRT) I still get a bit of flicker on the pans and zooms. I realise this might be the thin lines on the website rippling over the interlacing but am I missing anything else?
    Dropping in the .motn files into the FCP timeline and rendering produces the same thing. Have I missed a checkbox somewhere? Should I be using compressor?
    Any thoughts/questions would be really useful.
    Paul G
    Delivery medium: PAL SD DVD
    Timeline: Uncompressed PAL SD mixed with PAL DV footage
    OSX 10.5.6
    QT 7.6
    FCP 6.0.5
    Motion 3.0.2
    Quad core Intel Mac Pro 8GB RAM
    SCSI RAID
    Stephen Smith replied 17 years, 4 months ago 2 Members · 5 Replies
