Activity › Forums › Adobe Encore DVD › Progressive Scan Output from Interlaced Projects
  • Progressive Scan Output from Interlaced Projects
    Posted by Corbin Gross on January 14, 2008 at 9:41 pm
    I’ve been creating these short training videos in DV NTSC mainly because that’s the default setting in Premiere and I don’t have a lot of video experience. When I make a DVD I usually just use ‘Export To Encore’ and make an auto play, looping DVD. If someone wanted to collect, say, 30 or so of these videos and put them on a looping DVD, what’s the best preset to use? I like presets since I don’t really know what I’m doing. They’ll be showing the videos on 40″ plasma screens, with what kind of DVD players and connections I’m not sure, I want to be ready for anything.
    Do you guys think progressive scan is the way to go? Can you even do that from an interlaced project? I would imagine the highest quality would be ok since there’s only about 30 min of content.
    Thanks for your help.
    Jeff Bellune replied 18 years, 8 months ago 2 Members · 1 Reply
  • Jeff Bellune
    January 14, 2008 at 10:59 pm
    If the source video that you use to edit in Premiere Pro is interlaced NTSC footage, then keep everything interlaced all the way through DVD creation.
    Let the player and/or the plasma handle the deinterlacing for display.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
