Activity Forums Adobe Premiere Pro Progressive or Interlaced output
  • Progressive or Interlaced output
    Posted by Jason Wilsons on April 27, 2010 at 2:14 am
    There is an issue I can’t understand. I have progressive footage from my digital still camera and after finishing my edits now I am going to export it to encore to create the DVDs. As I know it, I have 2 options.
    1. From premiere CS4 direct linking to encore with transcoding the files in Encore. By this way, I guess the resulting DVD will be upper field interlaced within the Encore.
    2. Or like I used to do it, I can export it as progressive mpeg-2 .m2v file. Then import these files to a new project in Encore. This way, the files won’t be untranscoded in Encore. So the result will be a progressive DVD I guess.
    Currently, the resulting DVD will be watched on a regular CRT TV with a regular DVD player, so will there be much quality difference between a progressive or interlaced DVD?
    I read somewhere that if there is a fast movement in the footage, creating a interlaced DVD will create a better result, is this correct?
    If I create a progressive DVD, then TV does the interlacing task, right?
    Thanks in advance
    Slobodan Milivojevic replied 16 years, 4 months ago 3 Members · 3 Replies
  • Jeff Brown
    April 27, 2010 at 1:22 pm
    You have progressive footage to start with, so you cannot “add” interlacing*. Treat the whole project as progressive, including the DVD encode. Technically, the resulting DVD will be displayed on a CRT as PsF: Progressive-segmented-frame, which is another way of saying both fields display one progressive frame.
    LCD and plasma TVs vary in how they display interlaced: some show true interlaced, some process everything to 60P (or 50P).
    *technically, you can double the source frame rate and interlace the result, but your clips will be 1/2 as long.
    Clear as mud?
    -Jeff
  • Jason Wilsons
    April 28, 2010 at 12:51 am
    Thanks for the information. Then what happens if I direct link to encore. I have seen that the project opens as “upper field” progressive as default in Encore and I can’t change it.
    Should I continue to do same as I told in original post. Like exporting as progressive in Premiere, then imporing it to a new project in Encore?
  • Slobodan Milivojevic
    April 28, 2010 at 6:26 am
    Hi!
    First, make one custom sequence in Premiere, which will be
    Progressive.All default sequences are interlace, and this is
    Making a big problem to progressive workflow in Premiere and Media Encoder.
    With custom made progressive sequence, you linked project in
    Encore will be progressive, too…
