Activity › Forums › Avid Media Composer › Progressive HDV in Media Composer 2.7.2
  • Progressive HDV in Media Composer 2.7.2
    Posted by Luis Pinto on July 6, 2008 at 8:38 pm
    Hey! I’m going to recieve some material thatt’s been recorded in 1080p/25 HDV (PAL), and thats not a part of the Media Composer 2.7.2 package that I have. Does anyone know of a download or a shortcut in anyway, in which I can use the program still. It’s been recorded on the SONY HVR-V1E camera.
    Thanks alot.
    Michael Phillips replied 18 years, 2 months ago 2 Members · 3 Replies
  • Michael Phillips
    July 6, 2008 at 10:14 pm
    I am pretty sure it has a 1080p/25 project type. As long as frame rate is the same, you can mix formats…
    Michael
    Michael Phillips
  • Luis Pinto
    July 6, 2008 at 10:38 pm
    Hey!
    It does have that so I can use 1080p/25 even though it’s 1080p/25 HDV?
    If so! Thank you so much for your help!
  • Michael Phillips
    July 7, 2008 at 12:12 am
    I know that play and edit will work… I need to look to make sure capture can be done. I will also check v3 Media Composer to see if it added a native 1080p25 HDV capture.
    Michael
    Michael Phillips
