Activity › Forums › Apple Final Cut Pro Legacy › Progressive Encoding with FCP/ Compressor/ Cleaner ?!
  • Progressive Encoding with FCP/ Compressor/ Cleaner ?!
    Posted by Stefan Koler on January 22, 2010 at 11:01 pm
    I need to transform anamorphic Quicktime DV-PAL clips into progressive Quicktime H.264 (anamorphic) and MPEG-2 (anamorphic) clips.
    So I exported a Quicktime DV-PAL in Final Cut Pro 6.06, imported the file to Compressor and started encoding. I used the “Deinterlace” Filter.
    Unfortunately the field order is wrong after encoding, it looks bad and not like clean, progressive clips should look like.
    After this I tried Autodesk Cleaner. But the result was similar: It was progressive (no fiel errors), but the quality was bad as well – lot’s of artifacts….
    But there needs to be a way to get clean, beautiful looking progressive footage. Can anybody tell me how to do it with Compressor or Autodesk Cleaner or if there is a better encoding software out there (I’m willing to pay for it if it works) please tell me. Or which settings/ filters should I use?
    Jeremy Garchow replied 16 years, 8 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    January 22, 2010 at 11:11 pm
    DOn’t use the deinterlace filter in Compressor, but rather set your output fields to progressive in the Frame Controls tab.
    The results are far superior.
