Activity Forums VEGAS Pro progressive DVD from HDV
  • progressive DVD from HDV
    Posted by John Anderson on October 15, 2009 at 10:32 pm
    Hello,
    I have edited my HDV footage and need to get progressive SD DVD out of it. Do I keep the project settings as is (1440 1080 60i 29.97) and render 720 480 NTSC widescreen 24p ?
    Dave Haynie replied 16 years, 11 months ago 3 Members · 4 Replies
  • John Anderson
    October 16, 2009 at 8:06 am
    No need to change project to 24p ?
    Help, please!
  • John Rofrano
    October 16, 2009 at 1:17 pm
    Yes, that’s what I would do. You will have very slight black bars on either side (pillarbox) because SD widescreen isn’t truly 16:9 but you won’t notice it on a TV.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Anderson
    October 16, 2009 at 4:33 pm
    Thanks John!
  • Dave Haynie
    October 16, 2009 at 7:55 pm
    It may not be necessary going from HD down to SD, but for top quality frame-rate conversions, SD to SD, I have found the enable 2x or 3x supersampling in Vegas (assuming you have Vegas Pro) dramatically improves the conversion.
    I first did this years ago, to do an NTSC to PAL conversion. I had tried demos of all sorts of programs for this, but none did a good job. Though it took over a week (8.5 days) to render the 2 hour video from DV NTSC to DV PAL (then, a 1GHz PC, single CPU), it was well worth it (and proof that Windows could actually go over a week without crashing or asking to reboot..)
    -Dave
