Activity › Forums › Apple Final Cut Pro Legacy › Progressive Capture and Export
  • Progressive Capture and Export
    Posted by Joshua Lim on January 27, 2006 at 11:35 pm
    hi everyone
    i recorded my footage on the panasonic DVX100A (PAL 25fps) squeeze mode
    i captured my footage with the capture setting:
    DV PAL 48 kHz Anamorphic
    is this correct?
    for exporting to maintain the full quality
    my sequence settings are:
    PAL – CCIR (720X576) anomorphic
    field dominance NONE
    QT video settings
    DV PAL 100% quality
    is this correct?
    am i right to assume that since it’s progressive, there is no option on capture so i capture like the good ole’ fashion way DV PAL
    and for the sequence i should put the field dominance to none as there are no fields?
    really appreciate your expert opinion!
    thanks!
    joshua lim
    Joshua Lim replied 20 years, 8 months ago 2 Members · 2 Replies
  • Graeme Nattress
    January 27, 2006 at 11:50 pm
    There is no progressive DV format. Progressive DV cameras embed their progressive video inside the interlaced DV format. That’s why you don’t need special settings for import or export.
    The “fields = none” setting in FCP only applies to motion effects that are created inside FCP. It doesn’t effect footage at all.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Joshua Lim
    January 28, 2006 at 3:37 am
    thank you so much!
