Activity Forums Adobe After Effects Expressions Progressive, always positive wiggle?
  • Progressive, always positive wiggle?
    Posted by Navarro Parker on January 28, 2016 at 6:16 pm
    I have several shape layers, each with a replicator
    I’d like to have each replicator to count from 0~100, but in a wiggly, constantly growing method. That is, it never reduces in value, but increases in variable amounts over variable intervals to a specified maximum (usually 100)
    For example: Frame 00-30, grow from 0-16 copies. Frame 31-35 add 9 more copies. Frame 36-54 add 14 more copies, etc… until it reaches 100 copies when it stops.
    Xavier Gomez replied 10 years, 6 months ago 2 Members · 3 Replies
  • Xavier Gomez
    January 28, 2016 at 7:53 pm
    This should work:
    startVal = 0;
    endVal = 100; // max copies
    DTmin = 0.2; // DTmin/max : time interval min/max between changes
    DTmax = 0.8;
    DNmin = 2; // DNmin/max : change amount min/max
    DNmax = 5;
    s=t=inPoint;
    m=n=startVal;
    while (n
    Xavier
  • Navarro Parker
    January 28, 2016 at 8:02 pm
    Thank you!
    Is there a way for this to respect the timing of my existing two keyframes (0 & 100)?
  • Xavier Gomez
    January 28, 2016 at 11:22 pm
    Here is a possibility, not optimal since it calculates the whole every frame.
    If your keys are not far apart and the param averageChangesPerSec isnt too big, it should be fine
    startVal = 0;
    t1 = numKeys>0 ? key(1).time : inPoint;
    t2 = numKeys>1 ? key(2).time : outPoint;
    averageChangesPerSec = 1.5;
    seed1 = index+1000;
    seed2 = index+2000;
    a = 3; // controls time variations (close to 1 = small, bigger=more disparity)
    b = 10; // controls value variations (same)
    if (time<=t1){startVal;}
    else if (t2<=time) {endVal;}
    else{
    numSteps =Math.ceil((t2-t1)*averageChangesPerSec);
    t=0; times = [0];
    v=0; values = [0];
    for (n=1; n<=numSteps; n++){seedRandom(t+seed1, true);t+=random(1,a); times[n]=t; seedRandom(t+seed2, true);v+=random(1,b); values[n]=v;};
    t = (time-t1)/(t2-t1) * t;
    x = (endVal-startVal) / v;
    a=0; b=numSteps; while(b-a>1){j=Math.floor((a+b)*0.5); if (times[j]<=t){a=j;} else{b=j;};};
    startVal + x*linear(t, times[a], times[b], values[a], values[b]);
    Xavier
