Activity Forums Adobe After Effects Progress Bar (Diagonal Stripes loop)
  • Progress Bar (Diagonal Stripes loop)
    Posted by Max Dornfeld on January 13, 2017 at 2:14 pm
    i need a Progress bar in after effects. The diagonal Stripes should move as an endless loop. Has anyone a good tutorial for me?
    Best Regards.
    George
    Emre Anil replied 9 years, 8 months ago 3 Members · 2 Replies
  • Walter Soyka
    January 13, 2017 at 2:57 pm
    If you build a seamless diagonal stripe pattern, you can animate it endlessly with the Offset effect [link].
    You can build the diagonal stripes very fast with a shape layer and a repeater, or with the Grid effect and the Slant effect.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Emre Anil
    January 13, 2017 at 3:21 pm
    Hi there,
    I’ll try to explain here,
    Let’s say your loading bar has 50px height..
    11First create a composition (barInsideComp) with dimensions 50px * 50px, create 2 solids in this layer with your desired colors for the bar. Make a diagonal mask on the top solid. it’ll should look like this:
    Next, create another composition for the outline of the loading bar.. let’s say 500px * 50px.. (loadingBarComp)
    Put the barInsideComp into the loadingBarComp and add the following effects on barInsideComp layer
    Add CC Repetile effect. Set Expand Left & Expand Right values 225 for and choose Repeat from the Tiling drop down.
    Add Motion Tile effect.
    Animate Tile Center‘s first value (x) with the desired speed. You can put 2 key frames to this value and use loopOut(“continue”) or loopOut(“cycle”) expressions for continuous movement..
    Now you got the moving parts of the loading bar, just put the comp into a more stylish comp and you’re done..
    Hope this helps or at least give an idea..
