Activity › Forums › Apple Final Cut Pro Legacy › progreesive becomes interlaced after speed change
Posted by Jason W. miltt on June 25, 2005 at 7:21 amhi:
i have some animations and i change the speed to 200%, now they are interlaced and dont look so good.how can i maintain them as progressive?
thanks
Walter Biscardi replied 21 years, 3 months ago 2 Members · 3 Replies -
Walter Biscardi
June 25, 2005 at 10:40 amEnsure that you’re in a Progressive Timeline.
Ensure your Field Dominance is set to None.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Jason W. miltt
June 25, 2005 at 11:05 amthe thing is that the whole project is interlaced except these animations. are you suggesting to move everything to a progreesive timeline?
Walter Biscardi
June 25, 2005 at 11:38 am[ezichko] “the thing is that the whole project is interlaced except these animations. are you suggesting to move everything to a progreesive timeline?”
If your project is interlaced, then your animation has to be interlaced too. I thought you were working with a progressive project.
The answer then is to re-render the animation with the correct field dominance for your project. With most NTSC projects, that’s Lower Field, with most PAL projects, that’s Upper Field.
