Activity Forums VEGAS Pro Program to up scail SD to HD
  • Program to up scail SD to HD
    Posted by Paul Gregory on July 20, 2012 at 3:59 am
    I friend tells me that there is a program around that claims do a really good job of up scaling SD to HD but he can’t recall the name of it. I can’t see how that should be possible but if it’s able to do so it should also mean that you could use just a portion of the new file & still have a result as good as SD. Do you know what the program is called?
    Thanks in advance
    Aleksey Tarasov replied 14 years, 1 month ago 2 Members · 1 Reply
