Activity › Forums › Boris FX › Program that uses GPU
  • Program that uses GPU
    Posted by Zach Meissner on July 30, 2008 at 1:59 am
    My question is what video card would boris products RED and BLUE, benefit from the most? Looking into a new video card and these are my options.
    A Quadro FX4000/4500
    A 6800GT PCI-e SLI config (total of 512 RAM)
    Single 7800GT PCI-e 256MB card
    Do the products take advantage of the Quadro pro features? Or better to be in a larger RAM/SPEED setup?
    Thank you very much!!
    Peter Mcauley replied 18 years, 1 month ago 2 Members · 1 Reply
  • Peter Mcauley
    July 30, 2008 at 1:14 pm
    Well that’s a pretty good question. The applications RED and BLUE are quite different in terms of their needs and what it takes to make them operate in a speedy manor. Let’s start with RED – RED is a CPU based 2.5D compositing, titling and special effects application. It works best on the machines equipped with the latest multi-processors with several Gb’s of RAM and a good amount of free disc space. Blue is a GPU based real-time 3D compositing, titling and special effects application. It needs a very fast graphics card, preferably manufactured by Nvidia, a couple of Gb’s of RAM and a good amount of free disc space.
    So what configuration to recommend to run both applications on the same system? I would think you should go for a multi-processor equipped Windows system with a Quadro FX graphics card (4000/4500 is a great choice), at least 2 Gb of RAM (4 is better) and a striped raid array.
    I hope this helps.
    Peter.
