Activity › Forums › Compression Techniques › Program Stream Multiplexing Software
Posted by Tim Mcgonagle on February 19, 2009 at 6:10 pmHello all, and thanks in advance as always.
Any suggestions for a Multiplexer Software package that can create Program Streams? I’m aware of the Manzanita Systems “System and Program Stream Multiplexer”, but want to explore any other available options.
Best,
TimChris Blair replied 17 years, 7 months ago 4 Members · 6 Replies -
Daniel Low
February 19, 2009 at 7:57 pmManzanita is one of the better ones out there, usually you’ll find muxing as part of a transcoding system rather than as a standalone application or solution, certainly in the software world.
You’ve obviously used Google to look for other solutions, one of the popular free alternatives is provided by ffmpeg
There are all sorts of other options, it just depends on workflow, budget and resource.
Fonts are like cologne:A bad choice speaks louder than a good one.
Tim Mcgonagle
February 19, 2009 at 8:39 pmI’ve got Episode available already, and may try to work with that using exports directly out of Final Cut, at least before considering an additional purchase.
Thanks for the feedback.
Tim
Daniel Low
February 19, 2009 at 10:09 pmThere’s no reason to need anything other than what you’ll get out of Episode, if you do then your client is being particularly difficult!
If you get to that point, it’s likely you’ll need to move over to Windows as that’s where most of the other solution lie.
Rich Rubasch
February 20, 2009 at 2:35 amI think BitVice used to offer a free multiplexing software on their site. Could try that.
Rich Rubasch
Tilt Media -
Tim Mcgonagle
February 20, 2009 at 4:33 pmIn the past I’ve used hardware based encoding (Optibase) off of Digibeta masters, with good results – but it would improve workflow and eliminate costs to work straight through Episode.
Has anyone had any negative experiences with encoding MPEG 2 Program Streams in Episode?
Also, any suggestions for a good simulator to test and view these files?
Thanks everyone for always being so helpful.
Best,
Tim -
Chris Blair
February 21, 2009 at 1:20 amTMPGEnc will also do this and it’s cheap. In fact, I believe the original software guy gives away an older versions of it hoping people will pay for the upgrades. It’s called TMPGEnc Free. There’s a paid version that has additional features for only $37.
Chris Blair
Magnetic Image, Inc.
Evansville, IN
http://www.videomi.com
