Activity Forums Adobe Premiere Pro Program playback to SDI?
  • Program playback to SDI?
    Posted by Dirk Dejonghe on March 1, 2012 at 3:08 pm
    I have a MacPro with CS5.5 and Blackmagic Decklink installed. Capture from tape is OK. I hooked up a PAL SDI monitor to the SDI output on the Blackmagic card. Audio is in/out via Blackmagic too.
    When I play a clip in the source monitor, I get picture and sound out of the Blackmagic on the monitor. If I try to play a sequence in the program monitor, I get audio but no picture on the external monitor. How come? I need to check the de-interlacing on an external monitor to adjust the settings.
    How do I get the program on my monitor?
    Dirk
    http://www.postproduction.be
    Dirk Dejonghe replied 14 years, 6 months ago 2 Members · 5 Replies
  • Richard Knight
    March 1, 2012 at 5:43 pm
    As you using a Blackmagic sequence preset?
  • Dirk Dejonghe
    March 1, 2012 at 6:46 pm
    Richard,
    Yes I am using PAL DV 720/25i Blackmagic preset.
  • Richard Knight
    March 1, 2012 at 8:09 pm
    Is that a PAL DV 16×9 the 720 options are HD.
  • Dirk Dejonghe
    March 2, 2012 at 6:58 am
    It is standard PAL 4/3 interlaced. The clips play fine on the external monitor if played from the source monitor in PPRo, plays fine in the program monitor in PPro but no picture only sound on external monitor; I need to tweak some picture factors that can only be judged on the external interlaced monitor. Blackmagic Decklink Extreme 3D with SDI output, capture was via YC analog input, audio via XLR analog.
  • Dirk Dejonghe
    March 14, 2012 at 6:11 am
    Problem solved: after rebooting no more problems.
