Activity Forums Adobe Premiere Pro Program Panel size
  • Program Panel size
    Posted by Andy Stone on August 22, 2020 at 11:07 pm
    I’m somewhat new to Premier Pro so perhaps this is an easy issue to help with. Last night, I began editing a a project and I noticed the source and program windows were a lot smaller than in the past. Also, the program window looks as though it is set to portrait, but my files are all landscape. I can see the correct file (size and dimension) in the Source panel, but when I drag it to the timeline and view in the Program Panel, the file is small, and is landscape in the portrait panel. And the sides of the files are cut off.
    I’ve tried viewing in various ways — fit, 100%, 75% — but nothing seems to work. Also I’ve tried changing the dimensions ins Sequence Settings, but this does nothing.
    I’m attaching a screenshot. Can someone help? Thank so much
    Andy
    Daniel Carranza replied 6 years ago 3 Members · 3 Replies
  • Todd Perchert
    August 29, 2020 at 2:04 pm
    I’m a little confused by your post. What is you sequence and source dimensions? And are you wanting to edit in portrait?
    From what I see in the screenshot, looks like you made a sequence by dragging the IMG_1469.mov file from your bin onto the new item icon, creating a portrait sequence – that file looks to be shot in portrait. I assume that’s how you made the sequence, since the sequence matches that file name and not the file name of the source file shown. I am attaching your file with circles of what I am talking about.
    At this point, I would just make a new sequence and copy/paste everything from that old one onto the new sequence. But I would use a preset or that source file as your source, and not the one that you did use.
    Make sense?
    TC
  • Andy Stone
    August 29, 2020 at 8:44 pm
    Thanks.
    I figured it out and all’s fixed, now.
  • Daniel Carranza
    August 31, 2020 at 12:19 am
    Nice!
    And what exactly was wrong with your project? Was it your sequece?
    Best wishes,
    Daniel Carranza
