Activity Forums Adobe Premiere Pro Program Monitor stops after a Couple Seconds
  • Program Monitor stops after a Couple Seconds
    Posted by Pat Ford on January 21, 2010 at 7:03 am
    Just set up a video workstation at my job.
    CS3 on XP, 3 gigs ram. dual 1.7; Nvidia NVS 285. 128 mg ram.
    Cutting DV.
    The video on the program monitor stops after a coupls seconds. The audio plays on. Media Player handles the clip fine.
    NTSC monitor does not play program monitor content.
    I had this same problem on my home computer…can’t remember what solved it. Do you know?
    Pat Ford replied 16 years, 7 months ago 2 Members · 4 Replies
  • Mike Velte
    January 21, 2010 at 11:47 am
    Unplug your camcorder?
  • Pat Ford
    January 21, 2010 at 1:42 pm
    I will check that out when I get to work. However, am using a Sony DSR-11 for capture and to feed signal to the NTSC monitor…soooo, ultimately I have to have the firewire connection working to send the signal to the tv monitor. That how I have this machine…my home machine set up. The difference is that I have a stronger graphics card here…geforce 7800 gs…this one has 258mg of ram.
    Thanks Mike.
  • Pat Ford
    January 21, 2010 at 7:09 pm
    Ok, I have fiddled with playback quality and sound settings. No improvement there.
    I updated the drivers for the Nvidia Quadro NVS-285. Now the accelerated GPU radio button in playback setting will stay chosen instead of popping over to conpatible. But no improvement in main problem.
    The main thing I have discovered is that if you turn off the DSR-11, the program monitor will play fine. I have attempted to check if there is a problem with a setting in the deck but nothing is obvious.
    Thanks for any further ideas. Googling in general and on Adobe does not turn up anything.
  • Pat Ford
    February 8, 2010 at 5:13 am
    Bad firewire card.
