Activity Forums Adobe Premiere Pro Program monitor not refreshing to new sequence when in full screen
  • Program monitor not refreshing to new sequence when in full screen
    Posted by Alexandre Brandt on September 18, 2015 at 12:40 pm
    Hello folks,
    I’ve recently made the switch to Premier Pro from FCP 7. So far I like it very much !
    There is some minor behaviour, I don’t know if it’s a bug or normal… When I have my Program monitor in full screen mode and I switch to another sequence, the program monitor goes white and does not display the image where the playhead is in the selected sequence. To see the image I need to press the button for Toggle full screen again, it goes out of full screen mode and shows the proper image and then I press again and I get the full screen working again.
    Its a minor thing, but because I only work from sequences with rush reels etc I find myself having to press the toggle full screen button a lot, every time I switch sequence…
    Here are some specs for infos. I’m editing C300 MXF 1920×1080 50Mbit/s footage, so nothing overly crazy. I’m on a Macbook pro mid 2015. The media is in a Lacie Thunderbolt 2 drive and the external monitor where I have my program monitor and some other Premier windows is connected via HDMI to DVI cable.
    Any advice would be appreciated !
    Thank you !
    Producer | Filmmaker
    Geneva – Switzerland
    https://vimeo.com/channels/800406
    Alexandre Brandt replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
