Activity › Forums › Apple Final Cut Pro Legacy › Program edit lists/EDL problems
Posted by Barry Lank on March 25, 2008 at 6:49 pmAs part of our deliverables for this contract I am working on we have to deliver program edit lists. I am assuming the best way to do this would be to export an EDL, then save that EDL as an excel or text file so it can be read by anyone. Is that right?
Now my first problem lies in exporting the EDL. I have a multitude of different video and audio tracks… some video tracks up to 6 or 7 and audio tracks up to 12. Is this going to be a problem for EDLs? I read that they only supports 2 video tracks and 4 audio tracks… so how do I go about creating an EDL that would make any kind of sense to anyone?
Also I am unable to export some of the videos to edl due to missing timecodes and reel names. is there a workaround for that or do i have to go into every clip and put something in those two fields?
David Heidelberger replied 18 years, 5 months ago 4 Members · 9 Replies -
Bob Flood
March 25, 2008 at 7:26 pmHi justin
in a nutshell, you are correct, Edit Decision Lists can only Identify 1 video track and four audio tracks at a time, sometimes 2 in a KEY (bg and FG)
So, you need to export a separate edl for each video track as well as 4 audiotracks, so with 7 video tracks that would be at least 7 edl’s…great huh?as for Non TC sources, there are 2 note lines on each “event” in the EDL. One can be either the clip name or file name, and the other can be one of the 6 comments.
Also, dont worry about converting the files to a different text format. If they are asking for a “program edit list” then the EDL is exactly what they want.
hope this helps
“I like video because its so fast!”
Bob Flood
Greer & Associates, Inc. -
Bob Flood
March 25, 2008 at 7:30 pmone more thing
the edl will not export any nested timeline info, so you have to replace the nests in your show with a cut and paste from the nest sequence ie replace the single nest clip with the clips and tracks you used to make the nest.
Bob Flood
Barry Lank
March 25, 2008 at 7:50 pmIs it just me or would an edl for a 7 video track video be the worst way ever to piece together a video?!
Wouldn’t it make more sense to give the client an xml, or better yet the actual project file in the rare event that someone else would have to make changes?
With the 18 different videos we are doing I would have to make like… 250-300 edl files?!?!?
I’m going to see if we can change the deliverables to something more manageable and practical.
Bob Flood
March 25, 2008 at 9:25 pmJustin
I hear ya!
I know from experience that these deliverable edls are usually only used for modifying the show or finding shots to use as stock. I imagine they would just print them out, put em in the master tape box, and call it a day.
Perhaps a batch list from your final sequence would be sufficient?
hope this helps
Bob Flood
Barry Lank
March 25, 2008 at 9:36 pmYou hit the nail right on the head.
The bottom of a master tape box in an unorganized stock room seems to be the inevitable final resting place for these deliverables.We decided to export xml files and convert them to a readable text format.
Thanks for the help.
Mark Raudonis
March 25, 2008 at 10:16 pmJustin,
I’ve found that Network deliverable requirements often do not keep up with current technology.
Your edl requirement is a prime example. We’ve found that if you discuss it with the network, sometimes they will accept a “sequence” file instead of an EDL. Obviously, this will give them much more info to go on, but then you get into all those pesky “versions”. As previously mentioned, EDL’s are primarily used to detect stock footage, and music cues. An XML output of the project is probably the best bet.
Another example of “outdated” delivery requirements is the definition of “acceptable” resolutions in “AVID” terms. Many people are now delivering shows editing with FCP from start to finish, but the guy who writes the specs at the network hasn’t caught on yet.
Mark
Bob Flood
March 26, 2008 at 1:58 pmJustin
Glad i could help.
What are you using to convert the XML to Text? I often need to do the same thing just to get a more informative log of a project than a batch list
Bob Flood
Barry Lank
March 26, 2008 at 2:23 pmI just opened it up in textedit then saved it as a .txt document. It looks just like html source code.
David Heidelberger
March 26, 2008 at 6:53 pmI’ve got a program on my website that will translate an FCP XML to Excel. It’s a little bit homemade, in that you need to have a specially prepped timeline, but it works and it’s free. Just be sure to read the documentation:
https://www.davidheidelberger.com/software.html
I think that XML2Text can also now do the same thing (although it couldn’t when I wrote the program).
– David
